It is currently Fri Aug 15, 2025 3:26 am
PostPosted: Sun Feb 22, 2015 4:41 am
The disadvantage with that jig is obvious (apart from the size), you have to keep moving the media to stop grooving and uneven wear. Might not be such a problem with harder stones like Oil/Arkansas.
Which is why the best jig in the world is still yet another new design away.
PostPosted: Sun Feb 22, 2015 11:12 am
First name: sam
Last Name: guidry
State: michigan
Country: us
I use a veritas mk2 for establishing the initial bevel on shapton glasstones. Most of the time I hone by hand. It seems that I can get plenty sharp by working the micro bevel by hand. When ever I feel that I cannot get the desired sharpness by hand honing, I re establish the bevel with a guide. M one compliant against most honing guides is they don't seem to hold a Japanese style chisel very well
PostPosted: Mon Feb 23, 2015 6:37 pm
First name: Miguel
Last Name: Bernardo
Country: portugal
Richard Kell's honing guide holds a Japanese chisel nicely. Otoh the guide itself is a bit awkward to hold, but one does get the hang of it eventually.
PostPosted: Tue Feb 24, 2015 12:26 pm
That's exactly what I do. I learned to do it by hand and never touched a guide for some years. After getting the guide my sharpening improved because I could start with a solid base line. It's pretty easy to set up but not so easy that I'd want to use it every time I need to freshen an edge up.
PostPosted: Thu Feb 26, 2015 4:28 am
I use an Eclipse 36 (like the L-N), Veritas Mk II (with cambered roller and skew guide) and the Kell. Bit of a collection, yes, but each has its own uses and I've built them up over time as I needed them. (Diamond stones from very coarse to DMT's finest then welsh slate at about 8000)
Use these respectively for straight, square edged plane and chisel blades / cambered plane blades and skew blades / Japanese chisels, small block, miniature plane blades and spoke-shave blades.
Anything that fits goes in the Eclipse (because it's the fastest to use of course) and set up on the little jig like James Orr - I use a similar jig for the Kell, with dowels of different lengths to set blade projection.
Use these to establish any fresh regrind/hone, and touch up by hand as I go. (Hard leather strop and Autosol may be my next thing to try)
PostPosted: Thu Feb 26, 2015 4:29 am
P.S. Is it obvious I'm on a sharpening campaign at the moment!?
Users browsing this forum: Michaeldc and 15 guests
